Results 1 to 5 of 5
Thread: 2020 GT speedo Calibration
    2020 GT. Just swapped to 29.5 inch tall rear tires.
    I see the editor and the scanner have options, I tried making the changes In the editor and my speedo did not change at all.
    The scanner says my current gear ratio value is 494.08 I don't know what this number is or how to come up with my new one.
    Oct 2016
    Poland
    1,752
    You need to switch to calibration. Normally taken from IPC.
    So I switch the "learn from BCM" to "use calibration" and just input the tire sizes? Do I have to do the change in the scanner also? I'll try it when I get home today.
    Advanced Tuner LastPlace's Avatar
    Jul 2016
    613
    The scanner now lets you adjust the bcm with special functions, or use Forscan.
    Oct 2016
    Poland
    1,752
    Quote Originally Posted by LastPlace View Post
    +2018 is a different story, bcm changes with scanner are not so obvious...wont accept certain ratios.
