Ok, after work I reflashed my TCM only. Nothing major, just added 15% to all of the shift MPH tables except for the Pattern A and Pattern B tables. As you will see from my attached log, it drove pretty good until it hit "The Spot" when I leaned on the loud pedal a little from a rolling start . It touched on the same area again very slightly as I was getting on the interstate. I am absolutely lost as to why it decided to pull so much timing without any KR happening. IAT was good, but you will see that too. Yes my IAT fluctuated some on the interstate. I managed to get a bubble in the supercharger cooling system when replacing the oil pressure switch. There was audible noise when I hit "The Spot", but no KR. I don't get it... Can someone PLEASE tell me what happened today? on a lighter note, she pulled 1.58g/s on the way to work this morning, had some KR in the 1200-1400rpm range about 40-80kpa. Changing my shift mph alleviated almost all of that. Yay . Thanks in advance for any and all input.
