So I'm running into some new issues.
Recently I installed a FAST LSxrt intake on my 6.0L LQ4, I made the proper fuel injector adjustments into HP Tuner and the engine started right up but I'm having some issues.
At startup the engine will fire up but as its coming down to idle rpm it stumbles and dies. This is coupled at the exact moment when the A/C compressor cycles on and off, I'm assuming that the extra load from the compressor when its momentarily engaged by the PCM is too great for engine and it just stumbles and dies. I can hold the throttle open slightly and slowly let it down and the engine will idle just fine. I don't know of a way to stop the A/C compressor to cycle or to compensate for the momentary load from the A/C Compressor.
Second issue is when coming to a stop and putting it into park, as soon as I shift from any gear to park the engine will surge high between 1.5-2k rpm and then will slowly return to idle. I know this is throttle hang but I'm not sure at how to reduce it.
Lastly, My current tune is on speed density as I'm still VE tuning using STFT. I can still drive the car and record and drive on the highway but as soon as my clutch lockup happens the engine starts stumbling lightly and you can feel it shudder. If I accelerate too hard I can hear a backfire though the intake, I'm assuming at this point their is even much more of a load on the engine and its prolly running too lean as I have my PE disabled because of the VE tuning. Am I correct on this?
Please let me know if I'm missing anything..
