I have a 2015 2500HD Silverado 4x4 that I just installed a LSA supercharger on. I am using the LSA 3Bar sensor(12592525) that came with the blower. I have been doing a lot of reading as I'm trying to get it to run properly. I read that I need to change the VVE table axis, when I click on it there are options for .10-1.00 x0.02, .10-2.00 x0.03, or .10-3.00 x0.04 and the Label is MAP/BARO (Pressure Ratio). When I look at an LSA file it has different options and the label is Manifold Absolute Pressure (kPa). Does that correspond straight across or are they totally different animals? And how do I setup the scanner to read it?
Any help would be appreciated.
