Originally Posted by
AK49BWL
This engine is going to drive me up a wall in a minute. I just had the engine rebuilt about 500 miles ago, replaced a ton of parts, but nothing seems to want to fix a problem this 2003 Chevy Blazer (2 door, 2wd, LU3 4.3 V6, 4L60E Auto, 3.42 rear) has had since I bought it with 152k on the odometer.
With very little throttle, my MAP kPa is flying up. At idle, 0%, it's at between 38-41 kPa. With as little as 15% throttle, MAP jumps to 60 kPa. At 35%, MAP is 90 kPa. This issue has remained CONSTANT through replacing the catalytic converter, o2 sensors, every single gasket in and on the engine, the injectors, EVAP purge solenoid, PCV valve and its pipes (including the one that goes to the intake hat), MAP sensor (twice), IAC, then the entire throttle body, and all of the vacuum pipes and their connecting parts at the intake manifold. NONE of this has changed the TPS/MAP curve. I know it's not right because my mom's 2005 Blazer has the exact same engine and PCM configuration, and doesn't do this. I couldn't even get DFCO to activate AT ALL until I heavily dropped the throttle follower and cracker tables in the tune, because the MAP would NEVER drop below 28 kPa under ANY circumstance before I did that. If I shut down the IAC while cruising at 2000 RPM or so, let off the throttle, MAP will drop to 15-ish.
With the MAF on (essentially no tuning done yet), my LTFTs+STFTs are massively enriching, +12 to +20 across the entire table. MAF off, high spark copied to low, trims are leaning out, -4 to -12, mostly between 35-65 kPa... Higher than that and the VE seems to be almost set perfect from the factory. It does seem to respond to changes I've made in the VE table, but I swear with each progressive change my MPG gets worse and worse, and its ability to pull a hill without downshifting does the same. My next up part swap is going to be the plastic upper intake manifold, because I have a spare here on hand... But I have a very strong feeling that ALSO will not change a single thing. So what am I looking at... Cracked lower (aluminum) intake manifold? Bigger internal issue?
Now, it is worth noting that the engine runs smooth as glass above 750 RPM, very little knock detected (by the sensor at least), and it does have very good acceleration, but I feel like it could do so much better considering I've taken the clutch fan off and opened up the intake filter box for better airflow. It just feels like the power isn't there where it should be. My 1999 4 door 4x4 Blazer got better mileage on the highway than this thing does, and I never even got to tune that one. Any ideas? Should I just throw this thing against a wall and V8 swap? lol.
