Results 1 to 5 of 5
Thread: random rich/lean idle issue in closed loop, 2014 ctsv
    Feb 2018
    824
    driving around 3_31_2018.hpl
    At the end of this log you will notice that my commanded afr goes from 12.3 to 15.8 and my idle speed slightly changes (happening while in closed loop). To all the guys that are smarter than me what could be causing this issue? It happens randomly and is there anything in hptuners i can change/adjust to prevent this from happening? It's more of any annoyance than anything. thanks!
    13,559
    Looks like the cat test to me.
    Try disabling it and see if it continues.
    Feb 2018
    824
    Are you referring to the COT protection? is that what i should try and disable?
    13,559
    No.
    The cat test in the engine diag tab.
    Feb 2018
    824
    No.
    gotcha, i'll turn that off and report back, thanks.
