Originally Posted by
Hemituna
Using stock SRT pump, that should be plenty of fuel.
If your numbers are looking screwy, you should try using the Open loop base/fuel mass mult/vacuum mult table.
Rescale it for boost (neg numbers are boost, pos numbers are vac) and it will do boost comps for you.
Example in attached file.
"Think a stock pump with voltage booster and 60 lbs injectors is enough for this? Seems like I'm really compensating for something but I can't seem to see a way to log fuel pressure on this car. I guess Dodge doesn't have a fuel pressure sensor?"
