Looking for a tune for a stock 6.0 to give the truck a smidge more power for towing and or maybe fuel mileage at cruise speed.
Anyone have a file they care to share?
71 stock.hpt
Here's the stock file from an 08 LY6 from a 2500 truck.
To be honest, gaining MPG in a truck like that isn't going to be easy. I doubt that you would be able to gain much if anything with tuning if everything is working right. The biggest factors are some sensors and your driving habits. Clean the MAF, replace upstream o2 sensors with new OEM units if more than 100k miles old. Control your foot more, drive the speed limit or under to achieve good MPG. It's still a giant brick that weighs 6,500lbs going down the road.
Play with some of the PE settings to help give it a little more seat of the pants feel. Remove the long PE delay and play with the timing and VVT to gain some bottom end power. I suggest running 89 octane or higher if you start messing with timing to keep knock away. The 6L90e can also be tuned nicely if you know what you are doing and each vehicle is different so no tune is exactly right for everyone.
