Convert Raw Data to Circuit?
I messed up and swiped to record in Raw Data mode.
I really want to see this in circuit mode to compare with my other lap times. Is there an easy way to convert the data in to the circuit mode?
-Brandon
Unfortunately, there's presently not a way to recalculate timing for a session within the app itself, but you could still use the free edition of RaceRender to determine your lap times... If you take your data into RaceRender, the "Laps" button will most likely have your lap times already calculated for you (if you were at a known circuit track), and if not you also have the option to set a start/finish point yourself and then it will calculate the lap times based on that.
