Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: ZF8 Limp Mode
    Senior Tuner LilSick's Avatar
    Jan 2022
    fountain valley
    2,283
    gear ratio/tire circumference is stored in the BCM, not in the PCM or TCM
    if you have a Tazer it will let you change tire size but you are opening a can of worms going that route
    depending on your application hpt can change what is stored in the bcm
    try to use the special functions option in scanner
    Jan 2022
    fountain valley
    2,283
    oh yeah, forgot to mention... if you use scanner (special functions option) to change the ratio or the tire size on a vehicle that is equipped with ACC, the cruise control will then be disabled
    ACC and CC both
    and doing so will illuminate lamps on your dash
    not CEL but FWC ACC etc
    Thanks for the insight. I will look in the special functions menu. Didn’t think it would be in the scanner.
    I’ve also been wanting to find out how to see which shift schedule it is using. Seen people saying you can monitor it in the scanner?
    I’m trying to load my scan so you can see where it goes into limp mode and maybe put me in the right direction. Hopefully it has attached.
    Jan 2022
    fountain valley
    2,283
    it looks like you are using hpt's generic channel list
    you wont be able to accomplish much in editor until you figure out scanner
    shoot me a email if you want help
    tuned by tank [email protected]
    Email sent to you last night. Thank you in advance.
  6. #26
    I updated the MVPI3 to my Jeep through Bluetooth and the TDN app using my android phone. It worked very well and now have the special functions in the scanner. I change the gear ratio from 3.09 to 3.7 and the tire size from 27.1 to 30.5.
    Now the ABS light is on and I cannot reset it. The service ABS pops up in the screen when I first start it also. It drives fine and seems as if nothing else is affected.
    Any idea why the ABS is now throwing an error and how to fix it? I think I will try and change it back to see if it removes the error.
    Thanks in advance.
  7. #27
    I figured it out. In the special functions there is an option for the ABS system. Looks like after a gear and tire diameter change, it changes something in the ABS system and it needs to be reset. Went through the menu's and it reset the ABS system. warning light went off and all is good now. Thought I would share in case anyone else can find this helpful.
