Results 1 to 6 of 6
Thread: Drain fuel tank
    Nov 2013
    5
    Drain fuel tank
    2012 camaro ls3 need to drain the fuel tank what would i use in 3.6 to have the fuel pump run with just key on
    Sep 2007
    patton, pa
    160
    Quote Originally Posted by spd2612 View Post
    On my truck I just hoom up to the Schrader valve on the fuel rail and let it idle till it runs out
    2010 silverado 6.2 ,Doug Thorley try-y headers, cats deleted ,spectra air cold air, lifted with 33's,tsp vvt 1.2 cam hp tuners
    Feb 2017
    11
    go to diagnostics (just like when you need to reset LTFT) Under fuel tab command fuel pump on
    Jan 2014
    Australia
    1,984
    i think in the scanner turning on the pump just does its normal prime time and thats it, i usually just put say 180 seconds in the prime time and flash then just turn key on, just dont let it run dry u can kill the pumps real easy
    Jan 2013
    27
    I worked on a fuel test program where we had to drain and refill 20 cars, three times a day. This is how we did it. Never hurt a fuel pump. Some GDI cars would throw a low fuel pressure code, but that's it.
    2013 Lincoln MKS Ecoboost
    2002 Regal GS (3800 Supercharged V6)
    1996 Dodge RAM 2500 Cummins Turbo Diesel
    1982 Buick Grand National
    1965 Hemi Barracuda (43 jr)
    Nov 2013
    5
    Thanks 07Gts that did the trick
