Results 1 to 3 of 3
Thread: 2015 6L80e (Silverado 5.3L) Shifts not happening according to TCM tables
    So I'm not 100% if I missed something here or not. The reason I'm looking into this is every WOT besides 1-2 the transmission is basically shifting as fast as possible (0.075s).
    [ECM] 12050 - Fuel Cutoff RPM vs Gear: All set to 5900 RPM besides Neutral and Park @ 4000
    [TCM] 15020 - WOT Shift RPM vs Shift - Normal: All set to 5800
    [TCM] 15028 - Upshift Speed vs TPS vs. Shift - Normal:
    10 10 10 11 12 14 16 18 21 24 27 32 35 36 36 36 36
    15 15 15 17 20 23 26 30 35 40 46 51 55 58 59 59 59
    22 22 22 25 29 35 40 46 54 62 70 78 85 89 93 95 95
    [TCM] 15010 - WOT Shift Speed vs. Shift - Normal:
    1->2: 35
    2->3: 59
    3->4: 95
    2->1: 27
    3->2: 51
    4->3: 88
    VSS Tire Revs Per (both): 634.99mi
    1st gear shift WOT:
    5908 RPM @ 39 MPH - 350ms shift
    2nd gear shift WOT:
    5751 RPM @ 65 MPH - 75ms shift
    I can upload the files later on today if that helps.
    13,565
    So what is the problem?
    It's not shifting at 75ms and not breaking parts?
    .2500 to .3500 is a good spot for shift times in a heavy truck unless you want issues down the road.
    I'm not sure how its shifting at the speeds it does because the 2-3 shift doesn't line up to any of the tables. The 75ms shift is really really fast, you can feel it and I'm guessing its not going to last if I keep it like that.
    Also I just realized I failed and put this in the V6 section and not the V8 section... any way a mod can move this?
