Attached is a 2004 Silverado with SD 2 bar and running a Turbo.
OS is 1252063 I found a 2500 4l80 with same os, but would not segment over.
Anyone have a file that will segment with this file attached?
Need 3.7 beta to access the file.
Thanks.
Thanks.
Your base OS is 12606960, not 1252063. That's HPT's 2Bar SD enhanced OS #. The OS I see for 04 Silverado 80Es is close to the enhanced OS, but not the same: 12587603
On quick glance I didnt find an 80E with the 12606960 OS, you may need to change OS' if you can't find a file compatible with your OS.
~Erik~
2013 Sonic RS - manual, CGM, 6M, sunroof, mods in process
2008 TrailBlazer 3SS AWD LS2, loaded, dropped, modded, SE22 Performance tuned. And then some...
2002 TrailBlazer LT 4WD 4.2L I6, lifted, tires, exhaust, SE22 Performance tuned
I wonder if so switch back to non speed density, do segment, then switch back to SD again...
Strange I didnt need to do that before.
ScarabEpic22 already kind of alluded to what you need to do, find a file with your operating system 12606960 and do the segment swap. With that said we have ALWAYS recommended doing a segment swap to your STOCK operating system then converting to the custom operating system of your choice.Originally Posted by [email protected].
12606960 is a flex fuel operating system and there are no factory 4l80 files to segment swap from. I can segment swap it for you for a fee. PM me if your interested.
