Results 1 to 3 of 3
Thread: Lm-2
    Dec 2016
    36
    Lm-2
    I have a innovate LM-2.
    The reading of AFR On the LM-2 is different that HP Tuners by about 2.
    If the LM-2 reads 14.0 AFR the HP READS 16.0 approx.
    I set it up using the transform settings on hp, so I am at a loss.
    Tried grounding the ground wire for the signal ect....
    Innovate reading is correct HP is not.
    I checked the Voltage output from innovate and it is sending out the correct voltage
    My innovate gage in my car reads correct to hp tuners use the same settings
    What am I missing.
    Oct 2017
    14
    Why not just use the USB output from the LM2 direct to your laptop?
    Works perfect for me
    Dec 2016
    36
    Looking around on the net it appears that I am not the only one with this issue. It appears that the tool has these issues.
    That’s a great idea, I’ll try that.
    Malcolm
