Results 1 to 7 of 7
Thread: Camaro 2013 6.2 l99
    Oct 2017
    7
    Camaro 2013 6.2 l99
    Good afternoon. I apologize for my English. Because he translated "Google". The 2013 Camaro car is 6.2 l99 on the automatic transmission box. where in the settings to change that transfers were switched later. help me please. I use the program HP Tuner.
    13,565
    I'd try to help but even with that translated it's still very poor wording.
    It's very hard to understand what you are trying to ask for.
    Oct 2017
    7
    Yes, I understand perfectly. I want to do that transfers 1-2 2-3 3-4 switched not 1800 turns and for example at 3000 rpm
    Mar 2015
    Alberta Canada
    77
    If you want to change your shift rpm/speeds you go into the trans tab in HPtuners then to the shift speed tables and increase the shift speeds (kph) and/or rpm.
    69 Chevelle 418" LS3, 11.25:1,PRC 260 heads, TSP 235/239, Longtubes, dual 3", 4L80, 3.42
    2010 Corvette Grand Sport A6, Heartbeat blower, 78mm pulley/10% lower, Kooks Long Tubes, 224/232 blower cam, ID1050x's, ECS stage 1 fuel system, alkycontrol meth system
    Oct 2017
    7
    Thank you. I'll be there tomorrow.
    Oct 2017
    7
    Thank you so much. Everything worked out. The next step is to replace the crook on the compressor.
    Oct 2017
    7
    Thank you so much. Everything worked out. I adjusted the car as I wanted.
