Results 1 to 2 of 2
Thread: SOL STRATEGY and SOL BDY ID - can you change these in the PCM for 6R80 via VCM?
    Feb 2018
    2
    Well - I screwed up and sent the wrong PCM in to remove PATS for my swap. 2016 F150 with 6R80. I had 2 PCMs, when I realized it I contacted the vendor to see if it would matter (before I knew that the SOL STRATEGY and SOL BDY ID were critical) and the reply was "shouldn't matter".
    So now I'm a little stuck - I didn't see an entry for these two paramters in the VCM editor but I know it can be done. Is this a dealer/IDS only capability?
    Off-topic, but while I have your attention: I have a hum when PCM power on inside the transmission also (not running, just key on) - is this normal?
    TIA
    Advanced Tuner bbrooks98's Avatar
    Oct 2011
    Gainesville, VA
    301
    It's an IDS thing only so far, but it would be nice if HPtuners could add this in the future? Never noticed a hum on mine.
