Working with a 525hp LS3 crate engine from GM. This has the "ASA" GM camshaft. OS is from a Gen3 1999 Corvette. After lots of learning (and criticism) I have the engine running and idling pretty good. The car will start, idle, and run at WOT without issue. The car will also drive & cruise above 1,800 rpm without any noticeable issue. All testing thus far has been performed in OL.
Here's where the fun starts...
Off idle tip in (accelerating lightly from a stop) and decel at low rpm (below 1,600 or so) will produce bucking/trailer hitching. I have tried adjusting the VE table (helped a bit a first, then hit a wall). Tried commanding various AFR's (richer and leaner) after VE tables were adjusted with no help. I have discovered that increased timing upon acceleration will eliminate bucking, as will decreasing timing upon deceleration. The problem is that the ECU uses the same cells (as far as I can tell) for acceleration, idle, and deceleration. I have tried using the HO/LO spark tables and idle tables with the hi/lo spark values and adjusting the "TUMBLE FLAP CLOSED" values (used to determine if idle or HO/LO tables are used), but I can't make it work (high spark upon acceleration, low spark upon deceleration, medium spark for idle).
Anyone know how to accomplish this?
