Hey guys, in search of some info on controlling the bypass valve on a Hellcat Charger 2016. I see that there are tabs for bypass valve control but the issue im having is at about 5000 RPM boost drops from 18psi to 14psi and its not a gradual drop its an instant drop. In all the Hellcats I have tuned ive never had to adjust anything with the bypass valve as far as the tune goes so im unclear as to what changes i can make that would work or not work. So if anyone else has had this issue what are some changes that i could make to see if i can keep it closed under WOT. Thanks ill post a log of scanner with this but just look at around 5000 Rpm and you can see the kpa dropping off and take note i did have a boost gauge hooked up as well with my tech watching it, which is why i said its an instant drop in psi not like the scanner is showing a gradual drop. Any advice would be nice
