Originally Posted by
lafrad
leave the fuel pressure sensor in the line, its very nice to have to keep your injector scale sane. The ECU will be fine with normal fueling based off that.
the fuel pump module output is modulated, so it would be a pretty horrible wire for a relay setup for the new pumps... Do you have knowledge of the new fuel pump controller?
I haven't worked directly with the kit, but I think the worst that would happen if you just leave the factory module there and let it run is a code when its output isn't working to control the rail pressure. You may be able to just remove the factory controller and quiet the code and all will work fine.
