Results 1 to 4 of 4
Thread: 6.7 Powerstroke "Clear KAM" for Trans tuning
    Jun 2014
    Boise, ID
    68
    When I set this to enabled, will it continue to clear the KAM for the TCM every time I turn the key or is it a one time clear and then it will turn off. Just need to make sure once I clear the adapt tables, they won't continue to clear every time the truck is started or do I need to reflash with it disabled.
    Where did you find Clear KAM in HPTuners? Clearing the KAM should just wipe the keep alive memory then the vehicle will start relearning. I think the other function your thinking of is called disable trans adaptive. I haven't seen either of these functions in HPTuners though.
    Jun 2014
    Boise, ID
    68
    Quote Originally Posted by gilgamesh View Post
    It's in the Beta, Keep Alive holds onto the adaptive data. It isn't actually disabling the adaptive learning.
    That is a strange place to put clear KAM. Nice to see it somewhere though.
