Its a heads/cam ls1 with a fast 90mm throttle, i had the throttle open up until 0.7 volts and subtracted base airflow until it wouldn't hang, but then idle would feel like a switch, it would hang at 1500 rpm and then suddenly go down to idle at 800 rpm when coming to a stop, so i reset base airflow to stock and closed the blade to about 0.65v.
iac came up from 0 to around 40 it idles ok, hangs a bit but its bearable, if i subtract any base airflow it dies immediately after you start it.
now sometimes it dies randomly, i have a log showing that.
the other thing is i have added to the follower airflow table and still stumblesthe same when i blip the throttle, im i missing something?
iddle dead.hpt
in this log it idled ok for a couple of seconds after i put it in gear and then died.
iddle dead2.hpl
in this one it died on Park
iddle dead.hpl
