So if I am cruising along at say 35 mph and I let off the throttle it will continue to maintain its speed (and rpm, between 1200 and 1400) and sometimes even slowly accelerated and shift up a gear. Any ideas on how to combat this?
It is an 06 srt8 charger with a 426ci, thitek stage 2 heads, comp cam, id1300, arington 90mm tb and twin 7868 turbos.
You can see it briefly do it around 7:10:22. before I had to hit the brake.
