Yamaha CCU data Race Render video Sync
Hi guys
Is it race render capable of using the Yamaha CCU log into sync in with Race Render?
Or, is it there a convertor from CCU log file to something known for Race Render?
best regards
I don't believe I've seen any data samples from this Yamaha system, but generally if you're able to get the data into a conventional CSV format (or a similar text-based spreadsheet format), then chances are good that it will work with RaceRender. The main things it needs are for the data to be arranged so that each new row represents another set of data samples, and for a time column to be included so it has a timing reference for each of those rows.
