Originally Posted by
bbrooks98
Most of what I did with my 4c was move the converter lock up speed around and the tq rate at which it locks up. Increased oncoming pressures, maxxed out the general torque limits and raised the inferred rpm limit and lower clip to not trigger a wrench. I like to turn off anticipated shifting and torque based shifts. I've tinkered with tons of other stuff with ramp rates and shift speeds, but for the most part the car drove pretty well with just those things. Lock up feel is where most the time was spent along with shift speeds. That's all preference, mine I setup to ride the converter through 1-2-3 at moderate throttle.
Tuning anticipated I think you need to set your oncoming and offgoing pressures and then find the clutch fill time to match your anticipated shift point. The Max accel from what was said here shouldn't need to be moved much if at all to accomplish a 1.3ish 60ft. Rear gear ratio has a lot to do with it too i think, on my car the toughest thing was getting it to shift 1-2 fast enough at the track with 3.55 gears to not hit the limiter. Short gearing i'd have to command as low as 5200rpm to get a 7300 1-2 shift, but that was with anticipated off. Now with 3.15s its much closer to actual rpm.
