Results 1 to 6 of 6
Thread: cylinder/engine volume in tune.
    In a stock 05 gto tune, it has the cylinder volume as 0.70819. Times 8..that's 5.66 liters, when the engine is a 6.0. Why does gm do that? I know that effects air mass, which effects other aspects of the tune. In my tune the volume is .73999..so times 8 is 5.91 liters. It was already like that when I bought it, and I've left it that way. If I changed it back to stock, would I have to retune it, and would it even be worth doing?
    2005 gto A4
    Darton sleeved 427, prc ls3 heads, custom cam 243/257
    Fti 3400 triple disc convertor
    553/555 N/A 839/823 nitrous on hub dyno
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,459
    .70819 is correct from the factory. If it is .73999 and it is running good, I would not change it and retune unless you just want to.
    2013 Silverado 5.3, 6L80k 8.8
    Quote Originally Posted by Lakegoat View Post
    alright...yea, it's running pretty good. Just curious...
    2005 gto A4
    Jul 2018
    21
    Quote Originally Posted by 13qtr View Post
    I am new to tuning but am currently in process of gathering all information to flash my 1st and am thinking obviously it is best to flash with correct cylinder airmass right? I mean if the car is 6.0 but only programs 5.7 shouldn't I adjust this to reflect proper displacement while logging for initial ve table adjustment?
    Jul 2018
    21
    Aug 2012
    SV, AZ
    447
    The cylinder volume isn't used in gen 4 and newer computers.
