Results 1 to 8 of 8
Thread: any one have the vct just start dis abling its self ?
    Jan 2015
    47
    I have a customer who put a new ford racing motor part # m-6006-m50a1 which is a 15+ motor with the 11-14 phases that are supposed to make it compatible with 11-14 mustangs car runs ok but once in 1/2 throttle or more the vct disables car bucks has low power any ideas what would cause that
    Senior Tuner CCS86's Avatar
    Nov 2017
    Austin
    1,089
    You really need to post a log and a tune file to get meaningful help.
    Oct 2016
    Poland
    1,750
    Have you changed the cams as well?
    Jan 2015
    47
    tune is stock and the motor is rite out of the crate no mods just a cai which needs no maf cal
    Feb 2017
    TX
    761
    Do you have a log and tune?
    It could be the intake cam ay half throttle trying to advance further than 20* which is the limit for s550 phasers so it disables. Stock first gen will call for ivo 40* advanced.
    Jan 2015
    47
    Quote Originally Posted by Thatwhite5.0 View Post
    ok I'll check that out thanks
    Mar 2010
    27
    Are you using the 11-14 cams or the 15-17 cams?
    Oct 2016
    Poland
    1,750
    You can't use Gen 2 cams with Gen 1 PCM - Gen 2 cams rotates one complete revolution more between banks. Gen 1 cyl banks are like ~60' apart and Gen 2 banks are like ~400' apart.
    You can try to re-set the timing chains manually for Gen 1 or you can try those settings but not sure it will work this way.
