So I have this ghost problem I?ve been chasing. I just cannot pin it down. I?ve glashed this pcm many many times. If I had to guess it would be several hundred. If not, thousands. Like I?ve had the car over a year and pretty much every time I drive it it?s getting flashed several times. One because I had an issue for the longest that it would learn itself bad from a vacuum leak. Then I?m always making changes to the car. Just trust me when I tell you?ve it?s been flashed a lot. It?s a 2004 gto. The phantom problem is it will get stuck at .4% throttle randomly. Using it happens if I rev it a few times in neutral. Then it won?t even idle. I can turn the tps back some and it won?t ever go to zero. It just wigs out and starts reading higher. Ive bought several new sensors including a factory one. New Nick Williams throttle body. New maf. Changed the iac. Checked wiring. Cleaned out the plug with a micro Wire brush. Shake the wiring and it don?t change. It used to be able to be remedied by doing a tps reset but now it?s taking me having to reflash it. Ecm bad you think?
