Results 1 to 2 of 2
Thread: 2002 Corvette some backfires, scan and tune
    Jan 2009
    mass
    27
    I've building this car for some time, it's mostly stock other than long tubes, ported TB and CAI.
    The tune I have is also mostly stock, other than things like delete rear 02s for headers, I'm getting some backfiring and was looking for guidance of any adjustments I should look to make?
    I also noticed some Misfires on 3 and 8? I'm a newb to tuning but can navigate around HPT.
    I've also never driven this except for in the driveway.
    [normal start run.hpl 2002_Vette_modded.hpt
    13,576
    Attempt to figure out the misfires. Check plugs and wires, swap injectors around if you have too.
    Past that install a wideband o2 sensor and start correcting the airflow model for the header/TB/Intake you installed. The MAF and VE should be your main things to work on before getting way into it.
