Results 1 to 7 of 7
Thread: 5.3 2007 SD tune non boosted
    Jul 2015
    Poland (Europe)
    174
    Does anybody have any good starting point VE table for 5.3 form Tahoe on E38 PCM, 2bar SD OS, totally stock engine? Tried Tune Repository but no luck, also did not found on board.
    best regards
    13,559
    Can't you just copy over the stock VVE into the 2 bar OS and have your stock starting point.
    Of course you'd have to use an excel program to swap the numbers around to make it work with the 2 bar OS axis's.
    Dec 2016
    Raleigh, NC
    127
    You should be able to use the stock one and use Excel to transpose it and flip the axis around to make it work for the new OS
    Feb 2015
    Perth, Australia
    974
    stock 2bar.hpt
    copy and paste VE tables from that to start
    Jul 2015
    Poland (Europe)
    174
    Quote Originally Posted by lukearmstrong1990 View Post
    stock 2bar.hpt
    Thanks a milion.
    Now if i set table in scanner of math parameter LTFT+STFT, rows and colums linke in VE table, will that work correctly with NBo2 to adjust table for cruise ? For WOT i know i need to go with WBo2.
    Should i "Paste Special" by multiply ?
    best regards
    Jul 2015
    Poland (Europe)
    174
    Stock VE (IMRC open and closed) tables were empty, and i could not find VVE table.
    beest regards
    Feb 2015
    Perth, Australia
    974
    under the edit tab at the very top next to the file tab. select that and in the dropdown is virtual volumetric efficiency table
    when u apply custom OS they give you blank VE
