I'm trying to get this throttle body tuned but I cant seem to find anything for the gen 3 please help .
What do you need to know?
If DBW you can adjust the throttle body scalar settings and then re-calibrate the MAF and VE tables to get fueling back in line. Drive by cable will still require the same tuning. Idle airflow settings will also need attention.
Nothing is going to be cookie cutter about this, it's all unique to each engine setup.
