Hi guys.
What is the Max boost your are running on LBZ??
Does anyone know what stock boost is??
Thanks Jonas.
Hi guys.
Thanks Jonas.
Stock boost is 25psi. "Max" boost is going to relative to quite a few factors. Including turbo being used, fueling, supporting mods, ect ect.
09 Cobalt SS - E47+EFR6758 =
07 Silverado ECSB LBZ Duramax - Bunches of goodies
Hi.
Im running with a stage 1 turbo.
After closing the EGR i had to add about 75% more fuel to have a perfect AFR.
Now im running 18 psi. But allready much more power.
Im just thinking. :-)
What els are they using the enigne to?
It is only using about 1/3 off the fuel ammount at WOT. So it has to be constructed to somthing els than a silverado. :-)
First, how do you know you have a "perfect afr" on a lbz? Second, 75% more fuel is a whoooole lot more than you need especially at only 18psi.
The diesels I have made is good and no smoke at AFR 17,1. WOT.
After closing EGR valve. It ran ower 19,90. After adding 50% fuel I could start to messure the AFR. (Plex goes to 19,90).
Now im about 70% added fuel. And only at 17,8. No smoke at all. So still more to come. :-).
So i think after im all done i have added over 80% fuel.
