I bought an 01 3500 silverado with an 8.1 in it. The previous owner had removed the Allison auto and installed an NV4500 manual trans. They couldn't make it run after the swap, and sold it to me cheap. I disabled VATS, changed the transmission drop down to manual, pasted a factory stick trans timing table from a repository tune in it and few other odds and ends. It runs and drives well, but the MIL is on with codes P0700, P0748, and P0778. HP says MIL status is off. The first two codes I have SES unchecked and no error reported in the drop down. The last one is not listed.. Also the message center says "trans hot idle engine" I'm assuming this is BCM controlled? I ordered a resistor to solder in the temp sensor wires to make make it think the trans is @160 but if anyone has a better idea I'm all ears. I did not do a manual trans segment swap, I have HP Tuned a couple of 5.3s with stick transmissions behind them with great success without a segment swap, but neither were in factory trucks with a BCM. I'm also wondering if the Allison TCM is playing some part in this. The truck is going to be a tow rig for me so I'd like to get the annoying lights off the dash.
Thanks!
