Originally Posted by
TriPinTaZ
Are you sure your Wideband is reporting the proper lambada? Was it recently free air calibrated? .85 lambada x 14.1 stoich = 11.98 Air Fuel. You want to be between .89-.90 lambada.
What I was saying about the MAF is, specifically for the AFE intake, is if you multiple the entire MAF curve by 1.10 (10% increase over stock) you will be in the ballpark of where the MAF is accurate again for that mod. Meaning if the car asks for .85 lambada you will actually get pretty close to .85 lambada. You are well beyond 10% in the area you are seeing knock which is contributing to your .85 lambada reading. If your MAF is accurate at WOT then your PE table will be accurate. If you have not changed the min and max COT enrichment values to 1.00 then you could also be adding even more fuel here at times. But you won't be able to tell unless you add COT enable/disable to the PID list and data log it. Yes injector pulse widths will help tell the fueling story.
Have you messed with any of the Knock Sensor settings in the tune?
Once I get home I can compare some of your changes to my tune and share a datalog config file so that you log the appropriate PIDs.
