Results 1 to 5 of 5
Thread: 2016 silverado 6.2 D1 procharger fuel pressure issues
    Nov 2007
    MI
    686
    Hi, I have a stock 6.2 with a D1 on 10 psi, headers and catback. High and low pressures were falling off so we put in a high flow lift pump. Seems low pressure is still not where it should be and rail pressure is still nose diving after 4000 rpms and the engine will only take about 10 degrees of timing on a long pull, even when at .81-.85 lambda. When I command 12 degrees it knocks which seems a bit low to me. I'm thinking the low rail pressure might be causing the engine to not take much timing. What do you guys think? Also getting a P2635 (fuel pump 1 flow insufficient)
    10 degrees.hpl12 degrees.hpl16 silverado THS supercharged modded 13.hpt
    2018 Camaro SS, Maggie 2650, 103 TB, Big Gulp, E85
    13,564
    I don't do much with DI stuff but that's kinda rich for DI, could even be the fuel causing the knock. Seems a lot of the corvette and camaro guys run .85 to .89 lambda.
    Nov 2007
    MI
    686
    I agree but i've leaned it out and it only knocks more. Honestly .82-.85 should be completely fine. The half point leaner won't make that much difference. I'll post a scan at .85-.89 to prove my point though.
    My real question is: Is the drop in rail pressure the cause of knock?
    Feb 2016
    482
    Your tune is way off too much fuel
    Nov 2007
    MI
    686
    Quote Originally Posted by paulsmithsr View Post
    check my other post
