Car is a 2008 G8 when I upgrade to the 2 bar OS almost everything in my scanner stops working so I assumed I need to add everything again. When I try to add simple things like maf or timing advance almost everything is not in the drop down boxes. If I switch back to previous OS everything is normal no issues. I am using version 3.6 and have tried 2 times now with same result. Car runs and drives fine and everything in the Editor seems normal but scanner doesn?t have most of stuff normally used. Is there a advanced view for the scanner that I am missing?
