I’m using the Bosch LSU 4.9 sensor and controller provided by Aeroforcetech. AFR’s on the scan gauge make sense and there is voltage at the pigtail going to the MPVI pro.
I configure a channel using external channel 1, user specified, output = input/.5 + 9.6 (there’s some offset), parameter LM-1 (for no particular reason other than to provide a label).
It shows up fine on the configuration list but when I log data this channel disappears leaving just a blank line.
Is this an indication of a setup problem, no signal or what?
