Wide band problem
I’m using the Bosch LSU 4.9 sensor and controller provided by Aeroforcetech. AFR’s on the scan gauge make sense and there is voltage at the pigtail going to the MPVI pro.
I configure a channel using external channel 1, user specified, output = input/.5 + 9.6 (there’s some offset), parameter LM-1 (for no particular reason other than to provide a label).
It shows up fine on the configuration list but when I log data this channel disappears leaving just a blank line.
Is this an indication of a setup problem, no signal or what?
