First, I am not a tuner. I am working with my tuner to resolve an issue we ran into yesterday. Looking for some input and direction. I've spent quite a bit of time trying to research this issue, and posting this seems like the next logical step.
I have a 2016 Charger Scatpack - 6.4L, forged rods and pistons (Modern Muscle Extreme), 2.9L Gen 3 Whipple Supercharger kit. Everything else is basically stock. I'm running 91 octane pump gas as well.
I put a smaller pulley on the supercharger (went from 3.25" to 2.875"), and it's currently making about 12lbs of boost. I was running the Whipple tune on the car with the smaller pulley, and the car ran fine. I took it to the tuner to make sure the tune was supporting the extra boost and that the engine wasn't detonating.
Under partial throttle/partial boost, the engine was pulling a lot of timing, causing some knock. The tuner adjusted the timing and the engine seems very happy. He adjusted some of the fuel trims as well.
Problem we are having is the supercharger bypass valve is now fluttering/surging under partial throttle/partial boost. Just at the point where vacuum turns into boost, it's as if the valve can't decide whether to open or close. In addition to this, the throttle now has developed a slight "light switch" effect, where at about 75% throttle it goes into full boost and takes off like a rocket.
Without any adjustments to the stock Whipple tune, there was no bypass valve issues and the throttle was very linear all the way until full boost. I'm trying to understand how a computer adjustment (timing) can affect a mechanical part (bypass valve) so drastically? The throttle body was looked at during the surging at partial throttle, and it looks like the throttle body blade is holding steady during the bypass valve fluttering (the throttle body isn't fluctuating).
Any input and tips as to what we should look at and adjust would be very helpful and appreciated. I'm about to head back in about an hour to mess around with the tune again.
