Results 1 to 7 of 7
Thread: 16 Camaro Lt1w P1 Procharger Help
    Sep 2006
    Thorntown Indiana
    16
    P1 Procharger on 16 LT1 SS Camaro It will not go over 86.69 Lbs per min on scan pid Tried a known good MAF same
    Any one run into this see attach file Any help appreciated Has Kooks Long tubes and No Cats w P1 SC
    Feb 2016
    482
    Post log file
    13,565
    That particular channel stops logging at 86.69lb/min from what I recall.
    Sep 2006
    Thorntown Indiana
    16
    here is the log file
    Aug 2009
    Calibrating
    3,373
    Lambda or AFR error still works...
    Can also log dynamic airflow
    Sep 2006
    Thorntown Indiana
    16
    so with my autel scan tool I max out at 1.44 lbs per second same as 86.66 Lbs per min Is this the limit of the scan data pid in the VCM?? going crazy on this one
    Aug 2009
    Calibrating
    3,373
    655 G/sec...
    Sorry I don?t look at the other units of measurement
