Results 1 to 5 of 5
Thread: MAP sensor oscillation at key on. Seemingly high value when idling/running. VIDEO
    May 2018
    4
    This is after trying 2 different MAP sensors (ZR1 3 bar), checking the wiring to the sensor, replacing the wiring from the ECU to the sensor, and even tried 2 different ECU's (Both P59's with 3 bar SD OS).
    Anyone have any idea what this could be??
    May 2018
    4
    You can also turn the key off and it does the same oscillation for another 20-30 seconds.
    13,565
    Random question, how many MAP channels are you logging?
    Just the 3 bar channel or several map channels?
    Does removing the channel, then re-polling for supported parameters, then adding the channel back in help any?
    May 2018
    4
    Fairly certain I'm only logging the one MAP channel.
    Haven't tried removing the channel.
    Feb 2018
    22
    I had the exact same thing when I had a 1Bar map and 2Bar map graphing.
