Results 1 to 4 of 4
Thread: Misfire but only with MAF active
    Tuner apex2112's Avatar
    May 2007
    Davie,FL
    55
    I have an issue with a 408ci I'm trying to dial in, if I switch over to MAF only the engine misfires.
    If I tune only the VE I don't get any misfire?
    I'm trying to get my lower rpm fine tuned with the o2's so the attached logs don't have the wide band connected.
    The 2 tune files only have minor differences other than one is for tuning MAF and the other is for VE.
    The MAF sensor is new, replaced about a week ago.
    What would cause the MAF tune to misfire?
    04 2500 408 maf tuning with o2.hpt
    maf_02_5-20-2018.hpl
    04 2500 408 ve tuning with 02_2.hpt
    ve_02_rev2_5-20-2018.hpl
    May 2007
    Davie,FL
    55
    Well I jumped the gun, getting misfire with both tunes.
    Seems to happen mostly at idle.
    The SES light comes on, but shortly after driving light goes out only to come back once stopped again.
    Would it be advisable to adjust the misfire tables under engine diagnostics/misfire?
    Nov 2015
    In a sandpit
    444
    -You need to say what mods it has, cam etc...?
    99 TA, Texas Speed LS376, PRC heads, 233/239 cam, Fast 92mm, 95mm TB, card style MAF, Tick TR6060, Strange 4.11 12 bolt axle & clutchpack diff, Strano springs/dampers, Vette 18" wheels, Vette disks, CTS-V calipers, 16lb flywheel, long tube headers, no cats.
    May 2007
    Davie,FL
    55
    408ci has 90mm throttle body, aftermarket intake manifold(Chinese knockoff), 60lbs Deatschwerks injectors, not sure of the cam specs he said "its a mild cam with .600 lift" and compression ratio is 11.1
    In A 2500 4x4 with 38" tires
