Results 1 to 7 of 7
Thread: 1999 Silverado with 9373372 OS 4l80e swap help please
    Tuner in Training SSink's Avatar
    Nov 2011
    25
    So as the title states, I have a 1999 Silverado with a 5.3 that I just did a 4l80e swap on. It has a 9373372 OS and with the tune repository gone I cant find a tune that I can segment swap. Could anyone help with one or possibly steer me in the right direction for getting this tune taken care of? Thanks.
    Dec 2016
    10
    The main thing you need to change are gear ratios first you can google and find them for the 4l80e and did they install the swap plug on the transmission connector?
    Dec 2016
    10
    also the tuning school has a video on youtube for the exact situation your in the title is "How to do a Segment Swap using HP Tuners"
    Nov 2011
    25
    I’ve done segment swaps before but I don’t have a 4l80e segment with the correct OS to swap in. I emailed HP Tuners and they said that I need to change the OS. Any idea how I do that?
    Nov 2016
    25
    I have 99 Silverado 9373372 with 6.0 4L80e I could share. I need the 5.3 portion for the same OS.
    Jun 2010
    293
    It can be done with the 4L60E segment, you need 2 relays, and turn off some codes, update trans ratios and shift points etc, have done it this way several times no issues
    "To drive a 4L80E transmission from a 4L60E segment:
    - discard the 3-2 control solenoid signal.
    - drive the 4L80E 2-3 shift solenoid by using a relay to invert the 4L60E 2-3 shift solenoid signal
    -use the 4L60E TCC ON/OFF signal to control a relay which gates the 4L60E TCC PWM signal to the 4L80E TCC PWM solenoid.
    To invert the 2-3 shift signal:
    relay is connected as follows:
    - the relay control coil is connected between 12V and the 2-3 shift solenoid signal from the PCM,
    - the NC (off) relay contact goes to GND,
    - the NO (on) relay contact goes to 12V,
    - the swinging/gated contact goes to the 2-3 shift solenoid signal in the trans,
    i.e. so when the PCM has the signal off (12V) the relay turns it on (GND), and vice-versa"
    I FOUND THIS INFO ON INTERNET AND TRIED IT WITH GREAT RESULTS
    Jul 2018
    Virginia
    48
    https://www.hptuners.com/my-account/tunerepository/?
    check one ton vans for an OS that may work
