E39 - E39A swap
Hello I had an LFX 3.6 camaro 2014 and would like know if is posible swap an e39 on that engine ... the current pcm for that year engine is e39A ...
Regards
It should work, so long as the E39 is from a 2012 Camaro LFX. E39 and E39A are pin compatible. You would need to either relearn or disable VATS though. Why would you want to do this, though?
Thx for u reply... it?s because I had the pcm (e39a) dead... and the had an e39 available to start the car... fortunately I managed to recover the e39a...
