Still getting P0502: Vehicle Speed Sensor A Circuit Low (Permanent) since my tune and I just can't figure this darn thing out! I'm trying to learn all of this tuning stuff My vehicle logs are not showing any vehicle speed. My VSS is connected properly, pins in the ECM connector are double checked and in correct position. (I wasn't having any of these issues before my dyno tune. Blah!)
Anyone available to help with looking over my settings under the "Speedometer" tab? I read a lot about other people's VSS questions/issues, and look at other tunes, but it seems like a majority of those similar concerns relate to the T56 trans and not my TR-6060 (I can't find any literature that tells if settings will be the same for these two transmissions)
Vehicle: '68 Camaro with LS3, TR-6060, and E38 ecm all out of a 2013 Camaro SS
Rear tires: 335/30R18 --- 798 revolutions/mile --- 26.06" diameter (should be 81.87" circumference from what I'm finding?)
Rear gear ratio: 3.70
I went off beshyster's recommendation of taking my 3.70 gear ratio divided by 3.33 (40 divided by 12) to get 1.11 corrected gear ratio and have that plugged into my settings.
Hardware
Speed Output Type -- should I have this set to "WheelSpd", "VehSerial", or VehRep TOS" ?
VSS Pulses Per Rev -- is 40.000 correct?
Driven Pulse/Rev -- is 12.0 correct?
Non-Driven Pulse/Rev -- is 12.0 correct?
Vehicle Speed Output -- should I have this set to "Disabled", Rep TOS", or "Serial" ?
Pulse Average -- is 15 correct?
Max Period -- is 20 correct?
Serial Min Freq -- is 1Hz correct?
Gear Ratio & Tire Size
Driven Tire Circ. -- 81.87" but HPTuners rounded down to 81.850 in.
Non-Driven Tire Circ. -- 81.87" but HPTuners rounded down to 81.850 in.
Final Drive
Ratio -- 1.10:1
Ratio - Error -- 1.10:1
Sensor Calibration
VSS Tire Revs per Dist -- 797.98
VSS Tire Revs per Dist - Err -- 798.01 (HP Tuners wouldn't let me put 797.98?)
Any help/suggestions are greatly appreciated!!
