Results 1 to 3 of 3
Thread: Speed limiter question
    Jun 2006
    Pitt Meadows, BC
    58
    This is aimed for shifted.
    I read your how to do to raise the speed limiter, but i ntoced if you go to spark control youll see that theres the spark limiters/ spark ramp out with vss speeds for fwrd and reverse. HOw come we dont change those with the speed limiter ? What do those do if they're something different..eventhough they are related to the vss.
    Thanks.
    Nate
    Houston, TX
    349
    lol...
    The how-to was written before those parameters were added, you do have to change those. Change them on the spark limiter page, and on the torque management page.
    2.4L Twin Cam Cavalier Z24 | T3 Super 60 @ 9 PSI | FMIC | TurboXS RFL | Greddy Profec B Spec II | Custom HO Intake Manifold | 2.5" Charge Pipes | 2.5" Downpipe | HP Tuners | 5 Speed Swap | Team Green LSD | SPEC Stage 3 Clutch | Fidanza Short Shifter | Prothane Control Arm Bushings | Carbon Fiber Hood
    Jun 2006
    Pitt Meadows, BC
    58
    ok. mm..would re write the how too to make sure i've done it write
