Please read, help solution for anyone with a high stall TC:
I have a 3750 stall in my L36 and trying to drive in 3rd and OD has been very irritating and annoying since I’ve installed it earlier this year. It's to much of a PITA to reinstall the stock TC and I really like the high stall because of the low end torque and the quick boost into the GT1 cam powerband. It's great for the track but very difficult on the street. The most annoying part of this high stall TC is it wants to keep shifting between applying and releasing, particularly accelerating hills in 3rd and OD while maintaining a constant speed. I could never keep the throttle steady; I’d always have to accelerate to keep the TC applied to make the grade. There never seemed to be enough pressure to keep the stall applied or released. Here's what I have discovered to help alleviate the problem so far.
Anyone that is familiar with the TCC tables will know the TC only releases in 3rd and OD. The TC does not release in 1st and 2nd. For the TC to switch between release and apply requires using the clutch. I honestly don’t need the TC to release in 3rd gear because I'm constantly down and up shifting between lights and stop signs. This puts unecessary wear on the clutch. So to save frustration and clutch wear I've configured the TCC tables so the TC will not release in 3rd and this has helped dramatically in 3rd gear with the TC. My mpg has decreased by only a fraction and I've gotten use to the higher revs in 3rd. Now how do I deal with OD. I don't want to keep OD from not releasing because OD is when you really want the TC to stay released while cruising for a long period.
Thanks to the new version 12, we are now able to modify the TC duty cycles This is how I fixed the TC behavior in OD. I left the TCC tables for OD as is for a stock GT 3.29. There seems to be not enough pressure to keep the TC applied or released. The stock duty cycels just don't have enough oomph. I've started out by setting my max duty cycles to 99% and minimum duty cycles to 98% and success! The TC stays released while cruising and stays applied when driving up grades. A word of caution, I feel this may be to aggressive because I can really feel the TC applying and releasing while driving, it feels like shifts. By increasing the duty cycles I'm unsure what the long term affects are and I'm still experimenting with the duty cycles. This evening I am going to back off the duty cycles and set the min and max tables both to the stock max values. Maybe I don't need to be so aggressive at 98%, perhaps if I use the max stock values as the minimum that may save long term wear.
If anyone has any quesitons, please ask. I'm still trying to learn so please correct me if I'm wrong with any of my assumptions.
Thought I'd share
