Page 1 of 4 1234 LastLast
Results 1 to 20 of 80
Thread: Help with Active Exhaust valve control on 6th gen Camaro SS
    May 2018
    13
    I have a 2016 Camaro SS with the exhaust valves. In HPTuners I see under System > General that's there a Active Exhaust section. Has anyone messed with these to see if it changes when the valves open or close? I want to see if when it's in Track mode I can make them stay open all the time. Stock they will still close even when i'm just cruising at 40mph in Track mode and you have to give it a decent amount of gas for them to open again. I know I can pull the fuse for them but I would prefer to be able to put it in Stealth in the mornings when i leave then Track anytime else. Any help would be great. Thanks.
    May 2003
    South FL
    1,390
    I think 2018 C7 Corvette is the first year that HPTuners can actually access the Exhaust Control Module and change their functionality.
    Otherwise the only way to keep them open is to pull the fuse or install a Forza or Mild to Wild exhaust controller. This would allow you to program your Homelink buttons to open/close the valves. You have to set your exhaust to stealth mode and just use the Forza or M2W controller so they are either open or closed full time.
    [email protected]
    Owner/GM Calibrator
    Advanced Tuner Auto-Hentzschel's Avatar
    Sep 2015
    Schleid, Germany
    341
    I think, there is a bug in the editor. I work on a 2015 Z28, for German law I need to change the valve settings more to close. but whatever I do the valves do the same like before. also if I complete disable the exhaust valve system... the valves working like stock. I sacrificed 3 credits for this :-( HP Tuners seems not to change this feature.
    May 2018
    13
    So I changed Exhaust Valve Enabled to Disabled and it disabled them. I would change the modes between Stealth and Track and they would stay open. So it definitely affects them. I just don't know what any of the tables mean and what to change on them. I guess i'll continue logging them and messing with them and see what happens.
    Here's what some of the tables look like.
    Sep 2015
    Schleid, Germany
    341
    what ever you change in the tables, its always the same.
    even if you disable the Exhaust Valve complete. its still working like before. It looks like the software doesn't change the exhaust settings. I lost 3 Credits for that :-(
    Jan 2004
    Columbus, Ohio
    213
    I would also love access to these settings on the E92 and E92A controllers used in the 2016 through 2018 Cadillac ATS-Vs. However, different sources have stated the valves are controlled by the BCM or the CCM, rather than within the PCM.
    2022 Cadillac CT5-V Blackwing (733 whp)
    2022 Cadillac CT4-V Blackwing (716 whp), 10.750 @ 134.77 mph
    2016 Cadillac ATS-Vs (eleven ATS-Vs in the 9s)
    2008 Pontiac G8 (first G8 in the 10s), 10.727 @ 129.87 mph
    2000 Bonneville SSEi (first 3800 Bonneville in the 10s), 10.711 @ 125.71 mph
    1999 Grand Prix GT (first 3800 FWD in the 8s), 8.902 @ 154.90 mph
    1998 Firebird (first 3800 RWD in the 8s), 843 whp, 8.991 @ 152.12 mph
    1998 Grand Prix GTP (first 3800 FWD in the 10s), 9.499 @ 145.13 mph
    HPT Employee Engineer@HPT's Avatar
    fecadefa
    615
    Quote Originally Posted by Auto-Hentzschel View Post
    Which vehicle an OSID did you work on? On some applications the fuel control part has been moved to the ECM. Perhaps the exhaust control has also been moved to the ECM on those.
    Sep 2015
    Schleid, Germany
    341
    see the OS
    May 2018
    13
    I changed the Exhaust Valve Enabled to Disabled and it disabled the valve for me. Changing it to stealth and the valves would still be open. These settings seem to be in the FSCM for me. I haven't messed around with the tables yet though as i'm trying to figure out how it uses them so I can't say if changing anything in those actually works yet.
    fecadefa
    615
    Quote Originally Posted by Tapout Tuning View Post
    I'm pretty sure the FSCMs are supported on those cars already. Try version 4.0 please.
    fecadefa
    615
    The exhaust valve control should be in the FSCM in this case. I know others are reporting success changing settings on this FSCM type. Can you please email support a debug? Would like to make sure the FSCM actually gets written.
    Sep 2015
    Schleid, Germany
    341
    I not have write the FSCM, because the editor say me with red letters, "brakeable" should I write FSCM?
    fecadefa
    615
    Yes. The controls you're trying to change are in the FSCM.
    Jan 2004
    Columbus, Ohio
    213
    Quote Originally Posted by Engineer@HPT View Post
    Would this also apply to the 2016 through 2018 Cadillac ATS-V with E92 and E92A controllers? If so, should I also download version 4.0 and give this a shot?
    fecadefa
    615
    I can't say with certainty. Please get an infolog while connected to the vehicle and I can verify for you.
    fecadefa
    615
    Update: 16-18 ATS-V are supported, but those particular modules have DTC only support at this time. They do not have the tables shown above.
    Jan 2004
    Columbus, Ohio
    213
    Appreciate you looking into this. Is there any way to get these tables added? I've been requesting them since last year. Have written forum posts and sent in support tickets (#111620 and 112532) as well.
    https://forum.hptuners.com/showthrea...Cutout-Control
    fecadefa
    615
    I've reopened one of your tickets and it's in my queue. Will investigate as time permits and keep you posted.
    Jan 2004
    Columbus, Ohio
    213
    Much appreciated. Thank you!
    Sep 2015
    Schleid, Germany
    341
    should I write the FSCM? even it it say me brakeable?
