Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 71
Thread: VCM Suite v4.0 Now Available
  1. #41
    Apr 2016
    Iowa
    23
    I just updated to V4.0 and now cannot edit any of my already licenses tunes or read my vehicle. I keep getting an error that states Unlicensed interface. What do I need to do to sync things back up?
  2. #42
    Apr 2016
    3
    I just updated to 4.0, now editor and scanner won't open. Pop up box says "vcm editor has stopped working". I ran the installer again to correct any errors with same result. I then uninstalled, and reinstalled with same result. I'm running windows 7. Help please
  3. #43
    13,565
    Did you update your framework yet?
  4. #44
    Apr 2016
    3
    I'm one of those "old guys", so please bear with me. What do I need to do to update framework?
    EDIT: downloading now, thanks!
  5. #45
    13,565
    Just download it from Microsoft so you are up to date running the 4.6.1 that is required.
    https://www.microsoft.com/en-us/down....aspx?id=49981
  6. #46
    Jun 2018
    Australia
    15
    Quote Originally Posted by Lahmer_52 View Post
    im having the same issue!
  7. #47
    28,266
    Quote Originally Posted by rpm4740 View Post
    This typically means you are using an old application key, make sure to use your newest application key.
  8. #48
    Nov 2007
    11
    Getting unhandled exception errors when I try to open the trans segment of an ecoboost or try to compare the file to anything and view the comparison log.
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.ArgumentOutOfRangeException: Specified argument was out of the range of valid values.
    at ?.?.(Int64 , Int32 )
    at ?.?.(Int64 , Byte , Boolean )
    at ?..( ,  )
    at ?..( ?,  , Boolean )
    at ?..(? ?, Boolean , Boolean )
    at .?..ctor( ,  ,  , ? ,  )
    at ..(IList`1 )
    at ?..( , ? )
    at ?..( , ? )
    at ?..(? ,  , ? )
    at ?..( , ? , ? )
    at ?..( , ? , ? )
    at ?..( , ? )
    at ..??(Object , EventArgs )
    at System.Windows.Forms.ToolStripItem.RaiseEvent(Obje ct key, EventArgs e)
    at System.Windows.Forms.ToolStripButton.OnClick(Event Args e)
    at System.Windows.Forms.ToolStripItem.HandleClick(Eve ntArgs e)
    at System.Windows.Forms.ToolStripItem.HandleMouseUp(M ouseEventArgs e)
    at System.Windows.Forms.ToolStripItem.FireEventIntera ctive(EventArgs e, ToolStripItemEventType met)
    at System.Windows.Forms.ToolStripItem.FireEvent(Event Args e, ToolStripItemEventType met)
    at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEven tArgs mea)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
    at System.Windows.Forms.ToolStrip.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.7.2563.0 built by: NET471REL1
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
    Assembly Version: 4.0.12.0
    Win32 Version: 4.0.12
    CodeBase: file:///C:/Program%20Files%20(x86)/HP%20Tuners/VCM%20Suite/VCM%20Editor.exe
    Win32 Version: 4.7.2558.0 built by: NET471REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    C1.Win.C1FlexGrid.4
    Assembly Version: 4.6.20142.844
    System.Net.Http
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Net.Http/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Net.Http.dll
    System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    InTheHand.Net.Personal
    Assembly Version: 3.5.605.0
    System.Management
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    C1.Win.C1Chart.4
    Assembly Version: 4.0.20142.24286
    C1.Win.C1Chart3D.4
    {d7221b5f-1a96-4637-9f58-6b58f289b126}
    Assembly Version: 0.0.0.0
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
  9. #49
    I had inquired about adding more parameters to the Chevy 2.0 LNF in regards to increasing injector drive current. This is possible on the 2.0 LTG/LHU. I spoke with Corey about this, and I was hoping these new parameters would be present in this new update....however I'm not seeing them, or am i wrong?
  10. #50
    Thumbs up
    Just ran the update -- The installer uninstalled version 3.6, and the 3.7 beta as well. Did some logging & tuning today with Ver 4 and everything worked fine.
  11. #51
    Jun 2017
    10
    I'm new to this so this might be a stupid question, i have a 2005 Corvette C6 base (stock) and would like to buy the new MPVI2 interface but my question is do you have to purchase the VCM suite separately or is it included in the purchase of the interface?
    regards
  12. #52
    Quote Originally Posted by mazzerman View Post
    regards
    VCM suite isn't purchased separately, the interface and credits are purchased.
  13. #53
    Aug 2017
    10
    regards
    The suite is a free download. You can download and install it right now if you wanted to. In order to flash the tune to your vehicle you will have to purchase the appropriate number of credits as determined by this chart: https://www.hptuners.com/vehicles/
  14. #54
    Jun 2017
    10
    many thanks folks....
  15. #55
    Waldorf MD
    774
    Support for VW Passat 2.0 Turbo 2009-2015?
    Daily Driver= 2003 BMW 330xi
  16. #56
    Aug 2016
    Thunderdome
    389
    Are the legacy supported vehicles no longer going to receive software enhancements, new accessible and adjustable parameters to the existing software?
    I'd really like to be able to do/see more to the Caliber SRT and Neon SRT.
    I have a burrito in my colon, yet refried beans come out...
    How i know it's from the same meal? I didn't ingest corn any other time.
  17. #57
    Jun 2017
    44
    When will the upgrade from the mpv1 to the mpv2 be available
  18. #58
    Jul 2018
    When will the newest update show all the adjustment options like the older versions? Will they be coming in an update file? Comparing my file (vs 4.0.12) with mpvi2 to a buddies older version and mpvi1 it appears I am missing some of the options and tables
  19. #59
    28,266
    Nothing is different between mpvi1 & mpvi2 files, we've moved alot of tables to make them better organized but we didn't remove anything.
  20. #60
    Jul 2018
    is there a thread on the forums somewhere that shows what was moved where?
