Thread: Adding boost to pid
    May 2019
    29
    Adding boost to pid
    I have searched this to death and still can?t get it to work. Under math parameters but after that I really don?t know what to do. Have about 9 options for map and the function on the tutorial won?t allow the map to stay as the sensor. Have no idea what I?m doing wrong or right. Any help?
    Jun 2019
    13
    i watched this video to set mine up skip to 8:25 in the video...hope this helps https://www.youtube.com/watch?v=X5k_QeWq2jk
    Advanced Tuner PGA2B's Avatar
    Nov 2004
    St. Louis, MO
    471
    Use this and it will log negative and positive.
    ([11.98]-[51.98])*(([11.98]<[51.98])+1+(([11.98]<[51.98])*.04))
    Make sure you have the following PID's Logged:
    11 Intake Manifold Absolute Pressure in psi
    51 Barometric pressure in psi
    2013 OBM A6 CTS-V Coupe
    Mods: Headers back Billy Boat Exhaust, GripTec 2.65, 8.6 PowerBond Lower, LSX Innovations Solid Isolator, ID850's, NGK TR7IX's, Accel 9070CK Wires, Spectre CAI, SRI Ported Throttle Body, SRI Catch Can, NGK AFRM, 160* T-Stat, 0fx2gv Brick, Hard Line Delete W/3/4" Lines, FB 101 FMIC, Pierberg CWA50, Stoptech Drilled/Slotted Rotors, EBC Redstuff, Cut Stock Springs, Flat Bottom Steering Wheel
    2006 Black Raven STS-V (Traded In)
    Fully Modded: 459RWHP@5888rpm/451lbft@4696rpm
    Jun 2019
    I watched the video but when I do it on mine it returns a negative boost value. My MAP sensor is reading about 4.3 psi key on engine off so even if i do the "MAP(psi) -14.6" it comes back -3 psi boost.
    The most it hit was -12 psi on one of the logs and that was at about 1/4 throttle merging onto the freeway.
    It's a 2018 SRT Durango with a Whipple STG2 kit. Came with a replacement MAP sensor so I would really like to have the boost gauge to make sure i don't hurt anyt
