Results 1 to 20 of 20
Thread: Interface DOES NOT EXIST MPVI2
    I Triple checked the serial and verification code and I get Interface does not exist trying to add it too my account...?. just received this today. Emailing tech now
    Quote Originally Posted by MustangKiller View Post
    Please try again now, i believe its fixed.
    Chris...
    I count sheep in hex...
    Quote Originally Posted by Chris@HPTuners View Post
    Chris...
    Yes sir it is Fixed!
    Also is there a way you guys can update the Interface Bluetooth name too something more recognizable if not here is a screen shot after I paired it WT12-A was its name and Unknown device before it was paired Screenshot (38).png
    I was able too connect it too my Bluetooth but scanner says unable too find interface is the wireless feature not available yet?
    interesting, mine says this:
    also BT works with reading and scanning, but not writing (you will get an error message)
    Interesting..... Im happy to test with you as much as I can. I will re pair in the am and screen shot://www.newegg.com/Product/Product.aspx?Item=N82E16834154804hot step by step! fyi here is my laptop obviously up too date...... or ill send a .DAT
    Dec 2006
    Birmingham, Alabama
    156
    Mine also says paired to WT12-A. It will work fine with the usb cable plugged in but will not connect to the scanner or editor ViA bluetooth even though is shows paired
    interesting…. also I am not able to use Bluetooth at all. but I can Pair but it wont reconnect
    Dec 2006
    Birmingham, Alabama
    156
    Any update on making the Bluetooth work?
    Has anyone been able to use the MPVI2 via bluetooth or is it just me?
    Quote Originally Posted by rpmextreme View Post
    I will try again later im very busy at the moment but as of now I have been unsuccessful. I can pair but not reconnect so it seems. I am using a 2018 MSI GS65 laptop with the internal Bluetooth.Screenshot (43).png
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,261
    tested it last night on my mustang, worked fine using the newest public version of software.
    Aug 2009
    Calibrating
    3,373
    Where in the world do we get a verification code??? Serial number is easy... but not seeing how we get this info??
    Very frustrated
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Apr 2018
    Knoxville,TN
    11
    Mine also will pair with my laptop but says Interface not found when I try to scan.
    Quote Originally Posted by Ben Charles View Post
    Very frustrated
    VCM Editor or Scanner
    Help -> MPVI2 Verification Code
    Tuner in Training JustinWhiteTuned's Avatar
    Mar 2017
    Houston Tx
    39
    I?ve been trying to get the Bluetooth to work for the last 2 hours. Does it actually work yet or no? How can you send out a device that has no instructions at all?
    Nov 2009
    32
    Very frustrated
    There is a knowledgebase for MPVI2 under contact
    On the website. It shows how to add MPVI2, get the verification code and Re sync the interface
    I just tried again I turn off all security. deleted then I re paired the interfaceScreenshot (47).png then it froze I tried both versions . also when I plug it in another device shows up under the Bluetooth menu Screenshot (49).jpg no matter what I do it will not Connect just says paired
    here are the specs too my laptop
    Manufacturer Part # GS65053
    OS Win 10 Pro
    CPU Intel Core i7-8750H
    CPU Speed 2.2 - 4.1GHz
    Chipset HM370
    Color Matte Black with Gold Diamond cut
    Screen Size 15.6" FHD, Anti-Glare Wide View Angle 144Hz 7ms 72%NTSC
    Resolution 1920x1080 16:9
    Visual Experience
    GPU NVIDIA GeForce? GTX1070
    Video Memory 8G GDDR5
    Keyboard Steel Series per-Key RGB with Anti-Ghost key (84 Key)
    Audio Nahimic Audio
    Speaker Dynaudio Speakers 2W*2
    Memory 32GB (16G*2) DDR4 2400MHz
    HDD Capacity 512GB NVMe SSD
    HDD Interface NVMe
    Optical Drive Type _
    LAN Killer Gaming Network E2500
    WLAN Killer N1550 Combo (2*2 ac)
    Bluetooth BT 5
    Card Reader _
    Webcam 720p HD Webcam
    USB USB 3.1 Gen2 *3
    Type-C Port Thunderbolt 3*1
    Video Port HDMI (supports 4K@60hz), mDP 1.2, Thunderbolt 3
    Audio Port 1/1 SPDIF (ESS Sabre HiFi)
    AC Power Adaptor 180W Slim
    Battery Pack 4 cell (82Whr) Li-Polymer
    Dimension 14.08"x9.75"x0.69"
    Weight 4.14 lbs
    Manufacturer Warranty 1 year Limited warranty (Include 1 Year Global)
    Dec 2006
    Birmingham, Alabama
    156
    I have 3 brand new MPVI2s here. All show up as WT12-A and non of them will communicate with the scanner or Editor via bluetooth. I think there is something wrong with these early units.
    I have tried on 3 different PCs with the same results. Once the BT button is pressed the Bluetooth light will flash on the unit for several minutes even if I pair it to a PC.
    It will show up as WT12-A even before I press the BT button
    I believe I may have been the first too discover this lol. But im always told its( impossible ) or Its your (car) your not crazy mine is doing the same thing sorry I didn't post this sooner very busy
    Subject: [#133162]: Blue tooth will not connect
    ====== Please reply above this line ======
    Thank you for contacting support Bryan,
    We are aware of this issue and are currently working to create the fix. I'm being told it should be sometime monday when it's completed.
    Eric Krupp
    HP Tuners LLC
    www.hptuners.com
    M-F 9-5
    Ticket History(HPT Client) Posted On: 08 June 2018 08:21 AM
    Apr 2018
    Knoxville,TN
    11
    Eric Krupp
    HP Tuners LLC
    www.hptuners.com
    M-F 9-5
    very good to hear. I was starting to get very angry with hp tuners because every post about this situation hp tuners says they aren't having any problems connecting and wasn't saying anything to give us any hope. now that they are working on a fix I can calm down lol I've spent hours and hours trying to get the bluetooth to work.
